Hindmarsh
May 09, 2017Initiate
Nighthawk M1 Ethernet Port Timeout
Hi, We have a M1 Router which we are testing before purchasing more. Everything that we use if for seems ok with one exception. The Ethernet port seems to go in to some standby mode after reboot o...
UK-based
Dec 08, 2017Luminary
Has this problem been solved yet by a firmware update? I still have the problem with the Ethernet port timing out. I guess you're on the Australian Telstra network. I'm based in the UK with a provider calleed EE. When new firmware is released by Netgear, there are probably different versions for Telstra and EE. I'm currently on version NTG9X50C_10.20.05.00 - does this look anything like the Telstra firmware release numbers? My M1 is connected to an unmanaged Gigabit Ethernet switch, into which I also have 2 access points connected, for Wi-Fi distribution. I'm running the M1 without a battery but with a more powerful mains charger equipped with Qualcomm Quick Charge 3.0 technology (backwards compatible with the M1's Quick Charge 2.0). Before I replaced the supplied 2A charger, the M1 constantly rebooted when the battery was removed.
