Hindmarsh
May 09, 2017Initiate
Nighthawk M1 Ethernet Port Timeout
Hi, We have a M1 Router which we are testing before purchasing more. Everything that we use if for seems ok with one exception. The Ethernet port seems to go in to some standby mode after reboot o...
ArodiD
Dec 10, 2017NETGEAR Expert
Hi Hindmarsh,
We will release a new firmware to the public around Feb 2018 which allows end user to disable the standby timer and enable the ethernet port permanently. I will send you a PM with my details to discuss further.
ArodiD
UK-based
Dec 11, 2017Luminary
That's great news, ArodiD - thanks for following this up. Will this new firmware version also be made available to EE customers in the UK?
