Hindmarsh
May 09, 2017Initiate
Nighthawk M1 Ethernet Port Timeout
Hi, We have a M1 Router which we are testing before purchasing more. Everything that we use if for seems ok with one exception. The Ethernet port seems to go in to some standby mode after reboot o...
ArodiD
Dec 10, 2017NETGEAR Expert
Hi Hindmarsh,
We will release a new firmware to the public around Feb 2018 which allows end user to disable the standby timer and enable the ethernet port permanently. I will send you a PM with my details to discuss further.
ArodiD
W4WN
Jan 02, 2018Tutor
This is good news ArodiD! I've also been struggling with the ethernet port timeout. I would also like any additional information when available.
Also will the firmware be provided here on the netgear website?
Thanks
W4WN
