Hindmarsh
May 09, 2017Initiate
Nighthawk M1 Ethernet Port Timeout
Hi, We have a M1 Router which we are testing before purchasing more. Everything that we use if for seems ok with one exception. The Ethernet port seems to go in to some standby mode after reboot o...
UK-based
Feb 04, 2018Luminary
When I wrote my post (above) back in early December, I was on firmware release NTG9X50C_10.20.05.00. At the beginning of Jan it auto-updated to 10.22.03.00 (firmware build date 22nd Nov 2017), only after I had replaced the battery (I'm normally running my M1 24/7 on an upgraded mains charger without the battery). This version seems to have solved the Ethernet sleeping issue - I no longer have to tap the power button to wake the M1 from time to time.
There are still no options in the web-based or app GUIs to totally disable the Ethernet sleeping and force the Ethernet to switch on permanently after a reboot - hopefully these options will be implemented in a Feb firmware release, as indicated by ArodiD. The current solution turns on the Ethernet port after a reboot and keeps it on if there's activity and presumably termination.
Regarding the differences in firmware versions between countries/carriers and the limited support they are able to provide, I had a bit of a rant here, although I still didn't get a reply from Netgear.
PerthPhil
Feb 07, 2018Tutor
I am running current firmware and STILL having Ethernet timeout issues, despite Telstra assuring me it was already fixed.
