Hindmarsh
May 09, 2017Initiate
Nighthawk M1 Ethernet Port Timeout
Hi, We have a M1 Router which we are testing before purchasing more. Everything that we use if for seems ok with one exception. The Ethernet port seems to go in to some standby mode after reboot o...
W4WN
Feb 08, 2018Tutor
Mine here are :
Firmware Version NTG9X50C_10.20.05.02
Build Date 2017/11/24
AT&T US
Hindmarsh that's hopeful news on a forthcoming update, thanks. I've pretty much given up on these as unlike others here I've had no luck whatsoever getting them to connect to any router or switch. I've tried all the tricks mentioned in this forum, even changing the MAC address of three different brands of router to MACs from PCs & laptops known to connect via ethernet to the Nighthawks. My suspicion is my carrier does not want these being used in this manner. If anyone has achieved ethernet connectivity to an external router or switch here in the States I'd sure like to hear about it. Netgear Support, if you're listening here I'd be very curious to try the Beta...
WakeSS
Jul 25, 2018Aspirant
My Ethernet port still goes to sleep on reboot and possibly even a cell tower change? Randomly occurs and connected uptime timer resets.
This on new firmware on AT&T, version NTG9X50C_12.02.06.00 and have Ethernet Sleep set to disabled.
Is this isolated to AT&T firmware? they added the ethernet sleep option but seems to not change sleep on reboot.
I have to connect to device via wi-fi, push button, switch data offload to ethernet (link light then comes on) then swith offload back off everytime this happens or I manually reboot.
- WakeSSAug 02, 2018AspirantAnyone have any work arounds to have the ethernet port be active on reboot, loss of signal??
