Blubyu's avatar
Blubyu
Nighthawk M1 Ethernet Port
Is the internet port on this thing ONLY for data offloading? Or can I hook this to my WAN port on my firewall and use it as my internet connection? So far it doesn’t appear so.  My WAN port gets an IP address from the Nighthawk and it will pass traffic (from the firewall through the Nighthawk) for a few seconds and then the connection goes down. If I restart the Nighthawk then it will start passing traffic for a few seconds and then stop again. Is this expected behavior?
  • I'm currently using the ethernet jack to connect to my laptop and VPN into work.  I get an IP address from the M1, a 1GBPS throughput, and can stay reliably connected all day.  The only issue I've encountered so far is power-cycling when the battery is removed and the M1 is connected to the included power adapter and connected to a device using the ethernet jack.
    The M1 will power-cycle occassionally with a Win7 PC (maybe 1-2 every 8 hours) and frequently (every 1-2 minutes) when connected to a Mac running High Sierra.  Having the battery in, using the ethernet jack, and being unplugged from power (so far) has provided good results.
    I've also attached the M1, via ethernet, to an Apple Airport Extreme and was able to play around with the IP Passthrough and DHCP settings.  Using Bridge mode on the Extreme provided the best results so far.
    • Blubyu's avatar
      Blubyu
      I guess I will play around with it more.  So far I have had terrible luck getting it to work in my scenerio.  I have put it in passthrough mode and turned off DHCP.  My WAN connection on my firewall does get an IP number.  It just won't pass traffic after a few seconds.
      If anybody else has any suggestions then please feel free to let me know :)
      • MicW's avatar
        MicW
        Luminary
        Have you checked you have the latest firmware installed. The M1 was known  to put the ethernet port to sleep with the previous firmware pretty quickly. Which sounds like what is happening to you. I have mine plugged into a switch via ethernet and it provides data to my devices via that for 16 hours aday and does not miss a beat
