Shotgunmiss
Nov 29, 2020Aspirant
Nighthawk M1 everyday plugged in?
Can I use the Nighthawk M1 as an everyday whole house internet? If it’s plugged in all the time would there be a fire hazard with the battery? I’m assuming when you plug in the unit, it also charges t...
- Dec 02, 2020
Hi Shotgunmiss
If you plan to run the device 24/7, we suggest you to power the device with the PA only without inserting battery. This way, it will avoid the battery from getting hot and impacting the device's performance.
Blanca
Community Team
Blanca_O
Dec 02, 2020NETGEAR Employee Retired
Hi Shotgunmiss
Blanca
Community Team
Shotgunmiss
Dec 02, 2020Aspirant
Thank you everyone
