ContiGT's avatar
ContiGT
Nighthawk M1 external antenna connectors
Hi folks I am having problems with my M1 regarding external antenna signal strength - like no improvement! The tech lined the antenna up with the tower on the highest point on my roof but no result!...
  • W1lliam's avatar
    W1lliam
    Jun 04, 2020
    The problem isn't on that antenna but the antenna port on M1, these two ports only designed for low bands (such as B1/3/8/28..,etc.), unfortunately your environment seems preferred on B7 and that two TS-9 port does not help on B7. There are 4 antennas inside M1, designed for different bands.
