ContiGT
Jun 03, 2020Aspirant
Nighthawk M1 external antenna connectors
Hi folks I am having problems with my M1 regarding external antenna signal strength - like no improvement! The tech lined the antenna up with the tower on the highest point on my roof but no result!...
- Jun 04, 2020
The problem isn't on that antenna but the antenna port on M1, these two ports only designed for low bands (such as B1/3/8/28..,etc.), unfortunately your environment seems preferred on B7 and that two TS-9 port does not help on B7. There are 4 antennas inside M1, designed for different bands.
W1lliam
Jun 04, 2020Virtuoso
Quickest way to validate if the external antenna works, take it with you to where you have 4 bars signal, without external antenna, and plug the antenna to see if signal dropped. Theory behind is when you plug external antenna into TS-9 port, the internal antenna will be disconnected.
You can also check on singal information from SETTINGS->Nighthawk M1 Status->Diagnostic, looking at RSRP, RS-SINR, Quality also Current Radio Band what is changing between with and without external antenna.
ContiGT
Jun 04, 2020Aspirant
Many thanks for the reply! I tried as you suggested and signal strength inside was -110db, moved outside to the area I get 4 bars and read off -88db. Plugged the antenna leads in and signal strength did not change! It stayed at -88db ( with +/-2db variation).
I purchased this unit as a "near new refurbished" item - it appears all is not what it seems!
- W1lliamJun 04, 2020Virtuoso
Can you check on what is the Current Radio Band? TS-9 port does not support high bands
- ContiGTJun 04, 2020Aspirant
Sorry for my ignorance but where will I find that info? Under diagnostics? What am I looking for?
Under Diagnostics page, check on Current Radio Band info
Sorry found it! LTE B7
Since your M1 is now stayed on B7 as main radio band, adding extenrla antenna does not help. So, it might not be the problem on that antenna but TS-9 port can't do anything on high band, they all installed as internal antenna. Some people done rework with the antenna connection, you probably can try to Google for more information.
