ContiGT
Jun 03, 2020Aspirant
Nighthawk M1 external antenna connectors
Hi folks I am having problems with my M1 regarding external antenna signal strength - like no improvement! The tech lined the antenna up with the tower on the highest point on my roof but no result!...
- Jun 04, 2020
The problem isn't on that antenna but the antenna port on M1, these two ports only designed for low bands (such as B1/3/8/28..,etc.), unfortunately your environment seems preferred on B7 and that two TS-9 port does not help on B7. There are 4 antennas inside M1, designed for different bands.
ContiGT
Jun 04, 2020Aspirant
Sorry found it! LTE B7
W1lliam
Jun 04, 2020Virtuoso
Since your M1 is now stayed on B7 as main radio band, adding extenrla antenna does not help. So, it might not be the problem on that antenna but TS-9 port can't do anything on high band, they all installed as internal antenna. Some people done rework with the antenna connection, you probably can try to Google for more information.
- ContiGTJun 04, 2020Aspirant
Thanks for the info! Well that's $600 (antenna cost and installation) wasted. So the external antenna won't overide the internal. Its supposed to cover 3G, 4G, 4GX and 5G bands and a 9dbi gain!
I think I may have to have a chat with the Antenna Shop!
Thanks once again.
- W1lliamJun 04, 2020Virtuoso
