ContiGT
Jun 03, 2020Aspirant
Nighthawk M1 external antenna connectors
Hi folks I am having problems with my M1 regarding external antenna signal strength - like no improvement! The tech lined the antenna up with the tower on the highest point on my roof but no result!...
- Jun 04, 2020
The problem isn't on that antenna but the antenna port on M1, these two ports only designed for low bands (such as B1/3/8/28..,etc.), unfortunately your environment seems preferred on B7 and that two TS-9 port does not help on B7. There are 4 antennas inside M1, designed for different bands.
ContiGT
Jun 04, 2020Aspirant
Thanks for the info! Well that's $600 (antenna cost and installation) wasted. So the external antenna won't overide the internal. Its supposed to cover 3G, 4G, 4GX and 5G bands and a 9dbi gain!
I think I may have to have a chat with the Antenna Shop!
Thanks once again.
W1lliam
Jun 04, 2020Virtuoso
