Sixtsixmike's avatar
Sixtsixmike
Nighthawk m1 external antenna setup
Hello all,
Just ordered 2 Wilson 10dbi yagi's and cables and patch cords, etc.
My question is how do you have yours mounted?
Stacked, side by side, or + 45 -45
In in a rural area in east T.N. and only get 1 sometimes 2 bars @ 2-4 gb if I stand in the right spot.
Trying to limit my trips up on the roof if I can get the rig setup before and and just put some lag bolts in my pocket and a wrench and 1 and done this joker the first time! Thanks
  • I'm no expert in antenna design but this short video has some useful tips. It seems that the 90 degree (orthogonal) spacing, whether that be horizontal/vertical or +/-45 degrees is of most use in cities or locations where there are sufficient objects in the signal path to produce signal diversity, in which the simultaneously transmitted data streams (on the same frequency) are received at slightly different times, allowing the data streams to be differentiated from each other. However, in rural areas with very open spaces, there's little signal diversity, so the above video advises that the vertical stacking is most likely to produce the best results. The video also suggests the minimum spacing.
    And this article indicates that mixing horizontal/vertical and +/-45 degree polarizations between transmitter and receiver doesn't impact signal strength.
    In order to save you having to get on the roof too many times, could you do some trials with different antenna orientations and spacing from a lower location, using a speed test application? At least this might give you an indication of what's going to be the best solution before getting on the roof.
    • KarmusDK's avatar
      KarmusDK
      Apprentice
      I just bought two cross-polarized MIMO antennas with one horizontal antenna and one vertical antenna on each wire. Question is, how are the four LTE antennas configured - lower-left, upper-left, upper-right, lower-right. (There is actually six antennas, where the two uppermost internal ones are used for wifi - I assume either dual-band 2.4 and 5GHz or Tx/Rx configuration on one of either bands.) Which one of the TS-9 ports is the receiver and which one is the transmitter? Would it be best to do a dual polarization on the download (Rx) and ditto on the upload (Tx), or use cross-polarization on either one?
      • KarmusDK's avatar
        KarmusDK
        Apprentice
        (can't edit post no more) I guess it depends on the frequencies used. So let me clarify my question: are the internal antennas preconfigured for specific bands, or do they choose automatically depending on the local conditions?
