big_bob
Sep 06, 2017Follower
Nighthawk M1 Firmware problem after update with Dashboard
I recently updated the firmware to my Nighthawk M1 and can no longer access the Dashboard at h.home as it will not accept the modems password. When I try to login it displays admin which is un chan...
- Sep 18, 2017
also clear cache on your pc, this is causing some silly issues with the dashboard.
DarrenM
Sep 08, 2017Sr. NETGEAR Moderator
You will have to do a factory reset by holding the reset button for 10 seconds then the default login should work again.
DarrenM
RobRoyHiggins
Sep 18, 2017Tutor
