derbast
Apr 10, 2019Aspirant
Nighthawk M1 Gateway IP Change
Hi, i need to change the Gateway IP to 172.16.1.1 , but i cant.
Invalid IP Adress, Please use an IP adress within DHCP range.
But DHCP is Turned Off, wat can i do now ?
Firmware is the newest
i found it out, you need to change the dhcp settings before deactivate DHCP
1 Reply
- derbastAspirant
