Duckman328
Feb 06, 2018Aspirant
Nighthawk M1 Hotspot & Nighthawk X6 R8000
Are there any benefits of connecting a M1 hotspot to a X6 R8000 router? Sorry I am not computer savy but I have the X6 R8000 and I would think the range it outputs would be far superior to the M1 bu...
UK-based
Feb 07, 2018Luminary
And here's the final part 2c, which I had to remove IP addresses from to get it to post...
I don’t know the X6 R8000, so hopefully someone else will advise you on this. My access points are both full modem/routers in which I have disabled DHCP, firewall, etc. I also needed to change their gateway IP addresses because they were set to the same address as the M1. I put them in the same subnet as the M1 but outside the DHCP range of the M1. You can change the DHCP range in the M1 if you need to. When you change the IP address of your router you will initially lose access to its interface - you need to use the new address to gain access again.
Now go to part 2 above...sorry for the disjointed nature of this reply - I haven't encountered this problem before in this forum :robotfrustrated:
Duckman328
Feb 07, 2018Aspirant
Thank you much my friend. Sounds like I need to start tinkering. I have printed off your replies. As I stated before, I am not the most computer savy when it comes to networking. I work on a computer all day long everyday but the IT department handles all my issues so I never really got involved in all the WAN, LAN, DHCP, etc. etc lingo. I believe I can walk thru it though. I just need to get involved more and learn. Thank you again and hopefully I can get it running! That router wasn't cheap so I just assume use it but if I need to get a switch or a simple wifi extender, that may be my next option.
- UK-basedFeb 07, 2018Luminary
I'm sure you'll manage just fine - it looks like a good router. If you get stuck, do some searches on YouTube - there's a lot of help there. And of course, you can always post more questions here :smileywink:
- Duckman328Feb 07, 2018Aspirant
I just thought of one other question! Which avenue would be the best setup if by chance I decided to take the M1 with me on a camping trip and I didn't want to have to go thru the hassle of reconfiguring everything to get the M1 to just act as a normal stand alone hotspot? Thanks again
In that case, the best thing would be to set the X6 R8000 up as an access point, leaving the M1 handling all the router functions including the DHCP IP addressing. You could then just unplug the Ethernet cable and take the M1 camping and it would be functioning as it was originally intended - a hotspot allocating IP addresses and internet access to your mobile devices.
Happy camping :smileyvery-happy:
