Smiller14559
Oct 03, 2020Aspirant
Nighthawk M1 how to connect to deco mesh
How can I connect my M1 to my deco router system
- Hi Smiller14559, - Welcome to NETGEAR Community! - You can enable IP Pass-Through Mode to turn off the mobile router functionality and assign the network IP address directly to the attached device. - To enable IP pass through mode:
 1. From a computer that is connected to your network, launch a web browser.
 2. Enter http://192.168.1.1.
 3. Enter the administrator login password. The password is case-sensitive.
 4. Select SETTINGS > Setup > Router Setup.
 5. Select the IP PASSTHROUGH ON button.- Regards,
 Blanca
 Community Team
1 Reply
- Blanca_ONETGEAR Employee RetiredHi Smiller14559, Welcome to NETGEAR Community! You can enable IP Pass-Through Mode to turn off the mobile router functionality and assign the network IP address directly to the attached device. To enable IP pass through mode:
 5. Select the IP PASSTHROUGH ON button.Regards,
 Blanca
 Community Team
