Midnightsun
Mar 07, 2018Follower
Nighthawk M1 in Canada
Can the Nighthawk M1 be used in Canada with a dedicated mobile sim from Bell mobility?
JasonN
Mar 13, 2018NETGEAR Employee Retired
Hi Midnightsun,
I just wanted ton confirm which model M1 is that? at&t or telstra?
Please let me know :]
- Jason N
- JSchnee21Mar 14, 2018Virtuoso
I'm curious, too. Do you live in Canada or just visiting? The USA (and other) versions can be unlocked. So if you end up needed to use a local SIM this is a possibility as well. Though you will likely have to manually enter the APN.
AT&T claims I should be able to roam with my MR1100 there and use my unlimited plus data plan "just like at home." Similarly, I should be able to roam to all of Europe for $10/day. Has anyone tried?
When I roamed to Canada last year using my cheap ZTE 917 Tmo hotspot which has limited band support, connectivity was very hit or miss. Typically once I got away from the US border it didn't work at all. Hopefully the combination of the MR1100 and AT&T will work better.
-Jonathan
