UK-based
Dec 11, 2017Luminary
Nighthawk M1 IP addresses - allow both dynamic and static
 The Nighthawk M1 network IP address setup currently allows either dynamic DHCP address assignment within a specified range or fully manual assignment of static IP addresses to wired or WiFi connected...
UK-based
Dec 14, 2017Luminary
I've just found out that the Netgear support staff keep an eye on posts that have a high Kudos rating, so if you'd like your Nighthawk M1 to be able to give fixed IP addresses to printers (so that you can easily print to them) and other gear while still having DHCP automated IP address allocation for other devices, including visitors' equipment, please hit the Kudos button - thanks :smileywink:
