Woolaorc
Oct 18, 2019Initiate
NightHawk M1 IP Passthrough Gateway
I've been using the Nighthawk M1 in IP Passthrough mode for a few months with DHCP turned off and it's Default Gateway set to 192.168.1.1 (factory default). It is connected to my Synology Router (RT2...
tsoetanto
Dec 12, 2019Aspirant
Factory reset should revert it back to 192.168.1.1
