Blady
Jan 16, 2020Aspirant
Nighthawk M1 issue when charging while using
I bought my M1 Mobile Router a week ago. Now I discovered an issue if I charge my M1 while it is connected to LTE/4G network and one Windows10 machine (domain joined using VPN) connected over WiFi to...
JohnPeng
Jan 17, 2020NETGEAR Expert
This is a noraml alert when the battery temperature reaches to certain degree and charging will be stopped so that the battery can be cooled down gradually. Then charging will be resumed.
You still can use the device under this condition. It is not an error on the battery charging.
Thanks
Oxygene
Jan 19, 2020Apprentice
When using at high speeds it gets hot too and it goes to 0 mbits/s sometimes due to overheating... You are buying for speeds and you can't use it properly; battery charge issues or modem cpu issues because it is too hot... technology only looks good on paper...
