BusinessConnect
Apr 11, 2017Tutor
Nighthawk M1 Issues
Good Evening: I've got a Nighthawk M1 (Telstra Supplied) in use as the primary internet connection for a client as their Fibre Connection has been delayed. Generally speaking the device works well ...
ArodiD
Nov 14, 2017NETGEAR Expert
Hi BusinessConnect,
Are you using the device in IP Passthrough Mode or are you manually disabling WLAN and DHCP and setting a static IP on the device connected to LAN port?
BusinessConnect
Nov 14, 2017Tutor
Manually disabling WLAN & DHCP, Setting Static IP in the Device to act as the Gateway.
Device hasn't been used for 3-4 months since I posted, I have factory reset and used the device as a default Hotspot no custom settings and its operating as expected.. haven't tried using it as the Main Office Gateway Since.
