DwayneAlton
Dec 24, 2019Follower
Nighthawk M1 Killed by FW 12.05.05.12
I have a fleet of nighthawk M1. One is on consumer AT&T. The others are all on FirstNet. After the 12.0 5.0 5.12 firmware update, none of them will stay connected to the network. They also connected. ...
Matth118
Dec 28, 2019Guide
I have two of the same hotspots. One on ATT and another on FirstNet. Both are having the same issues since the update. Can't figure out how to roll back the firmware either.
- Blanca_OJan 13, 2020NETGEAR Employee Retired
Hi DwayneAlton Matth118 PapaSnarf CC559026
Please check your inbox. I PM'd you requesting for more information.
Blanca
Community Team- cmyorke1Jan 15, 2020Aspirant
Iam having issues with the update also. I am not able to get any service when using the ethernet port. I have 2 devices. The first one updated and I lost internet through the ehternet port. I switched to the other device still running 12.05.05.00 and it was working fine. within 24 hours it updated and lost the ethernet port on it also.
any assistance would be appreciated.
Chris
- JohnPengJan 16, 2020NETGEAR Expert
We are actively investigating the issue now.
Sorry for the inconvience and thanks for your patience.
