DwayneAlton
Dec 24, 2019Follower
Nighthawk M1 Killed by FW 12.05.05.12
I have a fleet of nighthawk M1. One is on consumer AT&T. The others are all on FirstNet. After the 12.0 5.0 5.12 firmware update, none of them will stay connected to the network. They also connected. ...
cmyorke1
Jan 15, 2020Aspirant
Iam having issues with the update also. I am not able to get any service when using the ethernet port. I have 2 devices. The first one updated and I lost internet through the ehternet port. I switched to the other device still running 12.05.05.00 and it was working fine. within 24 hours it updated and lost the ethernet port on it also.
any assistance would be appreciated.
Chris
JohnPeng
Jan 16, 2020NETGEAR Expert
We are actively investigating the issue now.
Sorry for the inconvience and thanks for your patience.
- 1eyedwillyJan 20, 2020AspirantAny resolution on this? My Nighthawk hasn’t worked right for the last couple of weeks. Never gets above 7 Mbps, used to consistently get 25+, and 95% of the time I get 0.13 or less Mbps. It’s essentially unusable.
