DwayneAlton
Dec 24, 2019Follower
Nighthawk M1 Killed by FW 12.05.05.12
I have a fleet of nighthawk M1. One is on consumer AT&T. The others are all on FirstNet. After the 12.0 5.0 5.12 firmware update, none of them will stay connected to the network. They also connected. ...
KCM88
Feb 12, 2020Aspirant
think I have the same issue and I am NOT ATT. I have an unlocked M1 running on a Google Fi Data Sim
- Updated firmware a few days ago.
- Devices: HP ENVY (new) laptop and iPad 6. Phone Android latest software
I set up the M1 on my laptop a few days ago, added the APN, and updated the firmware. I drove to a higher location where I would work and connected my iPad to the device via Wifi. It said one device connected and I ran a speedtest on my iPad. Awesome.
Then I drove to another location a mile away to try another speedtest BUT even though the M1 said it was connected and the iPad said it was connected, There was no internet. I connected my phone and then the M1 said 2 devices connected and my phone said it was connected. No internet on the phone either. I powered off both devices, turned the M1 on, then the ipad. No difference=no wifi. I powered everything off.
So I researched and saw something about turning off standby. There was no option for that but I changed it from 5 to 60 minutes.
Next day I am in my car again and power on the M1. Then I power on the iPad and do a screentest. Awesome. wifi works. I drive to another location 5 minutes away and the same problem happens all over again, no wifi. I NEED this to be reliable.
I saw in a forum somthing about the 2G vs 5G and which one do I have set? I have them both set to switch. I am signing into the 2G with the ipad.
Model: MR1100|Nighthawk M1 Mobile Router
