PatriotsUnited
Jul 30, 2019Aspirant
Nighthawk M1 LAN port slow compared to WIFI
Hi, I have an odd issue. I'm tring to set up the M1 as a modem via LAN cable through the IP Passthrough setting. I can get the inital set up right and all seems well. But the download speeds are b...
n3t
Sep 08, 2019Apprentice
I have never used the IP Passthrough feature so far, but do use my M1 often through Ethernet and so far always got the expected speeds of multiple dozens of Mbit/s.
Have you been able to find a solution? Make sure it's not the patch cable which is defective.
