LRFloyd
Jul 01, 2020Aspirant
Nighthawk m1 lights flashing with old and new battery
I have a Nighthawk M1 I bought it used almost a year ago, and from day one it would not operate with a battery. I have had it without a battery using it straight plugged in the whole time. The lights...
Blanca_O
Jul 08, 2020NETGEAR Employee Retired
Hi LRFloyd
Have you tried factory resetting?
Kindly contact support to better isolate the issue for possible hardware problem
http://www.netgear.com/support/contact.aspx
You will find several options for contacting support in the provided link. Thank you.
Blanca
Community Team
