Gu_Cervo
Mar 08, 2020Follower
Nighthawk M1 local storage
Does the Netgear MR1100 Nighthawk M1 Router support a 64gb micro SD xc?
- Mar 08, 2020
The following is documented in the release notes:
Micro SD Card Requirements
The mobile router supports SD cards up to 128 GB in the following formats: FAT, FAT-16, FAT-32, NTFS,
HFS, and HFS+Thanks
schumaku
Mar 08, 2020Guru - Experienced User
Out of wally brain, the last User Manual I have in the grey cells says 128 GB, but communty reports show much higher capacities.
JohnPeng
Mar 08, 2020NETGEAR Expert
HFS, and HFS+
Thanks
