soletto
Dec 24, 2018Aspirant
Nighthawk m1 low speed
Hallo,
i have similar problems speed at 2,4 ghz only max 72 mbit!!! Also with manually HT40 selecting.
I tried on 2 computers. This should be fixed because the router is very expensive.
soletto
ok problem solved i use the router while putting out the akku
