port16
Jan 31, 2020Initiate
Nighthawk M1 missing option to enable VPN
Wishing to connect the Hotspot to my Corporate VPN, looked in the manual and the directions are to access the web interface, choose setings > Advanced Settings > Other The only issue is there's n...
schumaku
Feb 18, 2020Guru - Experienced User
VPN Passthrough means that most VPN traffic can flow over the router - from the client to the business VPN concentrator.
Far to many requirements for a "generic" business class VPN client on such a device - this starts from customized controls and protocols over certificates, passwords required to unlock private key on your certificate, 2FA integration ...
For the moment - when I have it right - all these mobile routers don't have any VPN client at all.
port16
Feb 18, 2020Initiate
I should have come back and updated this post, but it slipped my mind. I ended up working my way into a support call, and was told that the VPN client was removed from all fo the hotpots, which is a bummer, since it's advertised int he manual.
I ended up buying a couple of TP-LINK Safestream Multi WAN VPN Routers and use them to connect everything behind the hotspot to the corporate LAN.
I think that having the VPN as a built in option would certainly be useful, but alas, it's not to be.
