Pyros's avatar
Pyros
Follower
Nov 18, 2019
Nighthawk M1 Mobiel router - network / share drive
Hi,
can someone help with my Nighthawk M1 Mobile router?
1. I have conected 2 PC to the router but they cannot see eachother.
2. i have attached attached a sharedrive trough USB port. i cannot see it/content on any of the computers, but i can see it when i'm login to the router or on Mobile app.
is it possible to set up so i can see other computers or the sharedrive at least ?
    • JohnPeng's avatar
      JohnPeng
      NETGEAR Expert
      Please disable Firewalls on the two PCs to see whether it can help. Make sure you share the drives in normal way.
      Thanks
