Henry_Hole's avatar
Oct 02, 2024
Nighthawk M1 mobile, connected to power source all the time?
Hi,
I have an older Nighthawk M1 (latest fimware) at our cabin. Lately (this year iirc) it has some problems turning on if we´ve had a power outage. For some years it´s been connected to a power source all the time, had one battery change, and been used abroad on travels. I´m very satisfied, but wonder if it´s time to replace it, since I can´t rely on it being connected all the time, especially after power outages.
Can anyone advice what would be the best practice for keeping it on all the time?
I haven´t tried it yet, but I know I can take out the battery, and have the router plugged in and use it only on power source through the USB-C.
Is there some settings anyone can recommend me, so I can be sure it will turn on properly after an outage?
Or maybe you can recommend me the better Nighthawk mobile to buy next?
I want to use it mostly in our cabin, and be able to have it mobile on travels.
  • Your best option?
    Pickup a backup power supply and run the M1 off that.
    That way if you have power die, the M1 doesn't die.
    normally you could leave the battery in as power but it isn't recommended to have the battery in them if ran 24/7 from wall power.
    • Henry_Hole's avatar
      Henry_Hole
      Tutor
      Thanks for the input!
      That´s actually a good idea!
      So, the backup power supply will then use the power from the main outlet. By experience, we´ve been told by the power company in our cabins region, that any outage has always been shorter than an hour before they fixed it, so probably I wouldn´t need a big power backup.
      I know this is beyond the mobile router question, but has anyone a recommendation of a backup power supply, preferably a cheap but good one? (so I know what to look for)
      • plemans's avatar
        Guru
        You don't need a massive one, just a nice one. I use APC and Cyberpower ones currently and have had great luck with them.
    • fredbv1's avatar
      fredbv1
      Why doesn’t the battery kick in if there’s a power outage?
        Henry_Hole
        Tutor
        That would be my question as well. I think it does to some extent, but when I arrive at the cab in, it seems 1) it has turned off, or 2) it has freeze, and the physical button doesn't do anything. So I have to take out and in the battery to get it going.
        Latest firmare.
        That's why I wanna try without battery, but maybe backup power will work.
