Azmann's avatar
Azmann
Nighthawk M1 Mobile Disconnect when idle
My Nighthawk M1 always disconnect mobile connection when idle. I cannot find any option in apps or webapps to disable this feature. I always leave my modem at home for 24 hours internet. Then the mod...
  • Blanca_O's avatar
    Blanca_O
    May 15, 2019
    Hi Azmann
    If there is no activity for a period of time, the device will power down to save battery power. Pressing the power button will wake it up. You can change the WiFi standby time by doing the following:
    Access UI > Settings > Setup > Wireless > change WiFi Standby to Disabled.
    Blanca
    Community Team
