johnliu
Jun 27, 2021Follower
Nighthawk M1 Mobile Hotspot shows "your data connection is disconnected"
Hi, I bought a new unlocked device M1 MR1100 online, went to a local ATT store and purchased a data plan, plugged in the sim card, tried to connect my phone to it. The phone did connect to the ho...
Blanca_O
Jul 01, 2021NETGEAR Employee Retired
Hi johnliu
Welcome to NETGEAR Community!
If you are connected to the mobile router but cannot connect to the Internet, try the following suggestions:
• Make sure that network coverage is available in your area.
• Make sure that your SIM card is active and enabled with data services.
• Wait one to two minutes for the mobile router to initialize.
• Confirm that your account is activated and that no other Internet connections are active.
• Switch your mobile router off and on and restart your computer or WiFi device.
Blanca
Community Team
