johnliu
Jun 27, 2021Follower
Nighthawk M1 Mobile Hotspot shows "your data connection is disconnected"
Hi, I bought a new unlocked device M1 MR1100 online, went to a local ATT store and purchased a data plan, plugged in the sim card, tried to connect my phone to it. The phone did connect to the ho...
Chucki
Aug 29, 2021Aspirant
After replacing the SIM card, I had trouble connecting. Followed all the various Troubleshooting directions to no avail. We are connected to our service but cannot yet connect to the Nighthawk. Even the Mobile app will not recognize this mobile router. Frankly, after two days of trying, I am my wits end. Please help.
- alvnas1500Jan 23, 2022Aspirant
I just ran into same issue. Did you find a solution?
Router been running for more than a year without issue, but suddenly wifi disapeared and now it says "Data connection disconnected".
I have tried rebbot switching sim and factory reset without finding any solution.
Did you?
- JohnPengJan 23, 2022NETGEAR Expert
Did you?
Data connection disconnected means the device is not connected to carrier's network. Please check APN setting and check with yoru carrier whether the data service is blocked to the device or any changes on the service of your plan.
WiFi disappearance is a different issue.
Please send a model.json log to me by private message.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
How to send private message?
Strange though that both wifi and cell connection happened at the same time
