johnliu
Jun 27, 2021Follower
Nighthawk M1 Mobile Hotspot shows "your data connection is disconnected"
Hi, I bought a new unlocked device M1 MR1100 online, went to a local ATT store and purchased a data plan, plugged in the sim card, tried to connect my phone to it. The phone did connect to the ho...
JohnPeng
Jan 23, 2022NETGEAR Expert
alvnas1500 wrote:
How to send private message?
Strange though that both wifi and cell connection happened at the same time
Click mt name and you will see this.
Bullseye555
Apr 22, 2022Aspirant
JohnPeng - I've just had the same issue here in Australia, using the MR1100-1TLAUS [Telstra branded]. I'd previously used this on the Optus network (both directly and via reseller Aussie Broadband) but am not getting the Disconnected error.
Was there any solution to the original post?
Happy to send you my JSON output too, if that helps
Thanks in advance,
Nick
