JW88
Nov 02, 2024Follower
Nighthawk M1 Mobile Hotspot shows "your data connection is disconnected"
Model M1100 Firmware NTG9X50C-12.06.39.00 I am having regular problems with data disconnecting. Factory resey=t worked last week. This time I had to try factory reset about 4 times before the co...
Love2love1984
Jan 04, 2025Aspirant
I've had exactly the same problem for a few months now. However, now even factory reset doesn't work. The wi-fi connection isn't showing available, therefore I can't go through set-up. It's pretty much bricked đĄ
I raised a ticket with Netgear but they want $99 from me to even offer technical assistance. Absolute joke!
I've tried to follow another thread and update the firmware, following this: Nighthawk M1 MR1100-100 does not broadcast the sig... - NETGEAR Communities
The update keeps failing though and i don't know what i'm doing wrong. I've downloaded the latest firmware from their website, which also fails. Very, very frustrating.
Might be worth a try for you. You might have more luck / tech knowledge than me. Any advice appreciated if you do suss it out. Good luck!
