Nightwho
Jan 17, 2020Aspirant
Nighthawk M1 mobile router not showing data usage
When will netgear release a new firmware update for Telstra Netgear Nighthawk M1 Mobile Router ? I updated to the latest firmware NTG9x50C_12.06.02.00 which caused my device to not display data usa...
- Jan 23, 2020
Hi Nightwho
Please be informed that firmware upgrade has been released for MR1100 Telstra Variant. This is to address the data usage issue not available. Kindly check your device for new firmware update and provide feedback.
Firmware version is 12.06.08.00
Blanca
Community Team
michaelkenward
Jan 18, 2020Guru - Experienced User
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Mobile Routers, Hotspots & Modems
Nightwho
Jan 18, 2020Aspirant
Thanks GURU.
Have copied over to Hotspot.:smileyhappy:
- JohnPengJan 21, 2020NETGEAR Expert
Fix for the issue will come soon.
Thanks
- Blanca_OJan 23, 2020NETGEAR Employee Retired
Hi Nightwho
Blanca
Community Team- NightwhoJan 23, 2020Aspirant
Thanks for the update . Yes, the new firmware works.
