PPolly
Aug 22, 2019Tutor
Nighthawk M1 mobile router
Since update on 12 August 2019 my router does not show usage data. I know this has been a problem in the past from viewing messages on this forum and have tried all the solutions offered, but my rout...
Blanca_O
Aug 26, 2019NETGEAR Employee Retired
Hi @PPolly
Welcome to NETGEAR Community!
Kindly reach out to Telstra to ensure that the device reached the billing server.
Please see this related community thread:
Blanca
Community Team
- PPollySep 02, 2019Tutor
I have spoken to my service provider, Telstra, who confirm that the device is connected to billing and that they are able to see the data usage at their end. Also the router works in all other respects than showing me the data usage. I am updated to firmware NTG9X50C_12_06.02.00
I have spoken to the techs at Netgear who advise that it must be a hardware fault, but it was all working fine until I updated to this firmware. I have tried factory reset twice.
Any further advice would be appreciated.
- PPollySep 04, 2019Tutor
Hi Bianca,
This is not solved for me as Telstra says no problem with device reaching billing.
Polly
- hippolyteDec 05, 2019Apprentice
Hi PPolly ,
I have just found your post after looking for help on the Telstra Community Forum.
My MR1100 stopped reporting data usage this week. My 790s also. There are a couple of us on the Telstra Forum.
Did you ever get a resolution?
Mine is on the same firmware: NTG9X50C_12_06.02.00. I have been using this since October 2018 and only got the issue this week.
When it went off in earlier versions it also affected billing data.
The link provided by Blanca_O, while useful at the time, does not appear to be related to this issue and was provided for the nefarious 'detecting service" issue which had us all stymied for months.
I see that EUS models got a firmware update to V12_06.08.00 this year.
- homemodemDec 09, 2019Tutor
Blanca,
I have posted elseware regarding this problem.
Since I updated firmware to NTG 0X50C_12.06.02.00 I too only see "Detecting Services" and cannot see my data usage.
I have tried all the recommendations in this and other posts.
Can Netgear please inform us what is happening. It is clearly not a Telstra issue!
Only happened, as appears to many others, since the upgrade in firmware!
