Limpylegs
Jul 13, 2019Aspirant
Nighthawk M1 Mobile
Hello,
I just recently ordered a Nighthawk MR1100 from Amazon that I'm using with Netbuddy. I'm trying to connect my HP Officejet 4655 using the wireless setup feature, but the printer can't find my hotspot. It's not on the list that normally shows up on the screen with the other hotspots,and it can't seem to find the hotspot even when I enter it manually. I know it works fine on my wireless hotspot at home but doesn't seem to want to work when I'm on the road.Is there a setting on these hotspots that I'm not seeing?
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi Limpylegs
Welcome to NETGEAR Community!
We want to check first if MR1100 broadcast WiFi network. Aside from the printer, are there other wireless devices that can detect the network? Can it connect and go online? If yes then we can confirm that MR1100 broadcast network.
As for the printer, how do you set it up? Is through the printer control panel or the installation CD? You may want to perform factory reset as the printer might still remember the old WiFi Network.
Blanca
Community Team
