td1812090
Sep 05, 2017Follower
Nighthawk M1 Modem Firmware Update Ruined Connection
Hello I have a Netgear MR1100 mobile wifi device and it worked great...UNTIL...the firmware update that it prompted me to do a few days ago. Now the download rate is awful - dial up speeds. Espe...
DarrenM
Sep 07, 2017Sr. NETGEAR Moderator
Hello td1812090
You may want to contact Telstra support the may be able to get you the old firmware to load on the device.
DarrenM
RobRoyHiggins
Sep 18, 2017Tutor
I have the same issue, telstra have been no help so far. the speed is on with 1 device connected but once a few are it slows to where some pages will not load?
