td1812090
Sep 05, 2017Follower
Nighthawk M1 Modem Firmware Update Ruined Connection
Hello I have a Netgear MR1100 mobile wifi device and it worked great...UNTIL...the firmware update that it prompted me to do a few days ago. Now the download rate is awful - dial up speeds. Espe...
DarrenM
Sep 07, 2017Sr. NETGEAR Moderator
Hello td1812090
You may want to contact Telstra support the may be able to get you the old firmware to load on the device.
DarrenM
sweete
Oct 26, 2017Guide
hahahahahaha
I contacted telstra about getting the firmware reversed and telstra told me it was not possible!!!!!!!
- RobRoyHigginsOct 26, 2017Tutor
yes i have spoken to Telstra advanced tech & Netgear tech support as well, netgear told me i needed to speak to telstra advanced tech as the firmware is done in house at telstra. They told me nothing could be done as it is updated OTA, i queried the provision on the units homepage & was told they dont know...
My unit is with telstra for evaluation at the moment, willl be interesting to see what they say
