BrianP82
Oct 26, 2020Aspirant
Nighthawk M1 monthly cycles starts
Monthly cycles starts is grayed out. Days left is stuck at 0. Can't change. I have done 3 rests and firmware is up to date. It is a AT&T version unlock and using Visible Sim. Any help would be ni...
Blanca_O
Nov 01, 2020NETGEAR Employee Retired
Hi BrianP82
Welcome to NETGEAR Community!
Does it display the same status on the MR1100 LCD?
How did you reset the device? Please remove the SIM card and hold down the reset button until you see a change in the LED.
Blanca
Community Team
BrianP82
Nov 01, 2020Aspirant
I did reset again without sim and used button in the back.
No charge. LCD shows data used and resets when power off the device.
