UzDragon
Apr 19, 2019Tutor
Nighthawk M1 MR1100-100 does not broadcast the signal and not visible on the WiFi list
MR1100-100 Nighthawk M1 with factory firmware stop broadcasting wifi signal after I enabled off loading Wifi. I reset it several times, connected to PC through ethernet cable but nothing works. Since...
W1lliam
Apr 20, 2019Virtuoso
Either you eonnect to M1 via USB Type-C, from PC, to access MR1100 on 192.168.1.1 or press RESET button, for about 5 seconds, on the back of MR1100, bottom side right next to TF card slot, to restore to factory default. Data offloading to WiFi would need to configure MR1100 to associate over another AP (MR1100 will be running as WiFi client in this case).
William
UzDragon
Apr 29, 2019Tutor
I have taken it to the shop to repair of reimburse. Hope to get reimbursed. Awful device and inadequate support...
