DUBJE84
May 18, 2018Tutor
Nighthawk M1 (MR1100-100EUS) - reboot loop when connecting to fast 4G+
Hi, I was looking for a solution of the following issue.
When I am at work and in a 4G area, (30Mbps speed) all works fine.
If I turn on the M1 in an area (at home) )with a faster connection,...
TeeJay74
May 18, 2018Virtuoso
I have seen one boot loop SW bug. It is fixed in the latest beta. Only workaround before beta version was factory reset, if it is continuous boot loop.
