DUBJE84
May 18, 2018Tutor
Nighthawk M1 (MR1100-100EUS) - reboot loop when connecting to fast 4G+
Hi, I was looking for a solution of the following issue.
When I am at work and in a 4G area, (30Mbps speed) all works fine.
If I turn on the M1 in an area (at home) )with a faster connection,...
DUBJE84
May 18, 2018Tutor
Where can I find the beta firmware?
the factory defaults didn't fix it for me.
TeeJay74
May 18, 2018Virtuoso
Please try again by pressing that reset button on the backside.
- DUBJE84May 18, 2018Tutor
I did use the reset button on the back... didn't help. :(
As soon as it makes the 4G+ connection it reboots again.
- TeeJay74May 18, 2018Virtuoso
Is it possible to test with different sim card ? It may be worth to try. If it still not working you need advices from some Netgear engineer.On the other hand factory style FW re-flash has sometimes solved some odd problems. Major bug fix FW release is coming soon.
Hi TeeJee , changing the sim card was tried as well. even different network, tried with and without an external antenna, all make no difference, it seems it isn't able to handle the 4G+ for some reason. Funny (not really) considering it was marketed and priced as the ultimate 1GB CAT 16 modem.
Can you let me know where are the firmware versions to be downloaded you are speaking about?
either old, new or beta releases?
