DUBJE84
May 18, 2018Tutor
Nighthawk M1 (MR1100-100EUS) - reboot loop when connecting to fast 4G+
Hi, I was looking for a solution of the following issue.
When I am at work and in a 4G area, (30Mbps speed) all works fine.
If I turn on the M1 in an area (at home) )with a faster connection,...
winger13
May 20, 2018Guide
I am using an AT&T version of this device.
I found in areas of low cell signal, device locks onto Band 12 (700Mhz), not reboots.
When used in areas of good signal, device locks onto Band 2 (1900Mhz), and constantly boots until it will NOT power on until battery is removed and reinserted. Bad device? or Firmware? or Both? Either way, this is the second device I had to return because of reboots - bad showing IMO from Netgear.
