DUBJE84
May 18, 2018Tutor
Nighthawk M1 (MR1100-100EUS) - reboot loop when connecting to fast 4G+
Hi, I was looking for a solution of the following issue.
When I am at work and in a 4G area, (30Mbps speed) all works fine.
If I turn on the M1 in an area (at home) )with a faster connection,...
TeeJay74
May 18, 2018Virtuoso
Is it possible to test with different sim card ? It may be worth to try. If it still not working you need advices from some Netgear engineer.On the other hand factory style FW re-flash has sometimes solved some odd problems. Major bug fix FW release is coming soon.
winger13
May 20, 2018Guide
TeeJay74 wrote:
...Major bug fix FW release is coming soon.
Can you shed some light on:
1) when (ball park is fine) the firmware will be arriving, and for what carrier(s) ?
2) what sort of things this magical FW will address ?
- TeeJay74May 20, 2018VirtuosoI am talking about retail model and its update delivery schedule, which seems to be late. Only Netgear development team knows exact delivery date. Its their decision. Fatal crash bug fixes are priority in this release.
