DUBJE84
May 18, 2018Tutor
Nighthawk M1 (MR1100-100EUS) - reboot loop when connecting to fast 4G+
Hi, I was looking for a solution of the following issue.
When I am at work and in a 4G area, (30Mbps speed) all works fine.
If I turn on the M1 in an area (at home) )with a faster connection,...
DUBJE84
May 21, 2018Tutor
So this is the reply I received from the "experts" of netgear support:
"Update from NETGEAR:
Hello Joey,
This is regarding your open case with NETGEAR.
I just received a feedback from our team and the reason why your mobile router is rebooting when connected to the 4G+ network is because it cannot handle this type of connection. The 4G+ is not one of the supported bands for the Mobile router. It supports:
LTE/4G 1/2/3/4/5/7/12/29/30/66
3G 2/4/5
Therefore you can only use 4G with the device and cannot use 4G+ with it.
I apologize for the inconvenience this has caused you.
Thank you for your time and patience.
Again, thank you for choosing NETGEAR.
Clarisse
Expert ID: 46194
NETGEAR Support Expert"
So they are saying a Cat 16 modem can't handle a Cat 6 connection. I am sending my device back to the retailer for a refund. It's garbage. And the support seems to be of the same quality.
Hello Joey,
3G 2/4/5
Clarisse
Expert ID: 46194
- winger13May 21, 2018GuideI am laughing so hard right now. Did the engineers not talk to the designers? Did Netgear Support really get that bad? Or did we all get duped buying a device supposedly capable of 100+Mbps download speeds (LOL me included)?
In all seriousness, I have owned Netgear products for many years. It does seem their overall support (and possibly their product quality) has taken a big dump, literally, in recent years. This is so unfortunate.
I have an open ticket for the past 2+ months - it's up to level 2 support now , and you wouldn't brought the quality of the support I am experiencing. It is not good. - JasonNMay 30, 2018NETGEAR Employee Retired
Hi Everyone,
If you are still having this issue. Can you please PM me the answers to the questions below so I can forward it to my internal team. Thank you :]
- Are they still having the problem?
- Contact info?
- If they contact support and what is their case number
- What is the FW version they are running?
- What is the SKU of their MR1100 device?
- Which battery are they using? W10 or W10a
- What is the exact issue they are seeing and how often?
- How easily are they able to reproduce the problem?
- What do they do to resolve the issue? do they reboot the device, pull the battery reinsert or do something else?
- How is the device running? Running on battery, plugged into USB of the computer, plugged into the ac power, plugged into AC power no battery inserted?
- Where is the device being used? In a fixed location or on the go?
- Jason Nguyen
- networksmanJun 14, 2018Aspirant
Hi
Was this ever resolved? I am looking at buying this exact model from Amazon for use in the UK and USA and I am concerned I will have issues if it connects to a 4G+ network.
Can anyone please advise?
