HM-BB
Sep 10, 2019Follower
Nighthawk M1 MR1100-100EUS SMB CIFS
I've been trying to access the M1 via CIFS/SMB (primarily from a Windows machine, but also Android) I have used USB and mcro SD, FAT32 and NTFS file systems. via wired and wifi. The server does not ...
n3t
Sep 10, 2019Apprentice
You are not the only one, see this thread from a year ago: https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Nighthawk-M1-MR1100-100EUS-unable-to-access-the-SD-card-using/m-p/1575556
Unfortunately, no solution was ever posted, and I actually never tried again to see if one of the firmware updates which were released since then might have fixed it. Apparently not, if it still does not work for you either. :-(
