madkiwi
Nov 14, 2024Luminary
Nighthawk M1 MR1100 as IoT modem for vacant home
I set up my new Netgear Nighthawk M1- model MR1100 with a Simbase SIM card and it seems to work flawlessly with AT&T (set for roaming data). I am using the device as a modem for a vacant home to mana...
madkiwi
Nov 18, 2024Luminary
Apparently a graveyard is more active than this forum. If anyone had the same questions as me here are the answers, found by trial and error.
AT&T will force a session reset after a week.
You can remove the battery and run it off the power adapter. If power is interrupted the MR1100 will restart without having to press the power button.
